HELP with glow plug issues
trooper632
Utopia, TX
Hello all, new to the forum. After reading some of the posts, this is the issue. checked each glow plug with test light, and each one lights up. Now I just put a new ford gpr109 on the m1009 and after the key is turned on, the small blue and orange wires are showing they are getting power but nothing to the glow plugs and the wait to start light will not illuminate. any help would be appreciated. also it appears that there are no fusable links that are burnt. thanks donny
CCATLETT1984
Saint Clair Shores, MI
on that new relay you put in, do you hear a click when you turn the key to run? the blue wire should not have power, its a ground (the controller switches the ground to activate the plugs, as the power wire is ignition hot.)
trooper632
Utopia, TX
no click when the key is turned on, the blue wire nor the small orange wire have power when the key off. when the key is turned on both the blue wire and the orange wire are hot. no wait to start light ever comes on. the controller under the dash is there but there is nothing plugged into it, I assume that is where the CARD would go, but nothing is there.
