That looks really good Ted! I think you should try to make the soft top fit over that Turret/rear support setup. It is way stronger in a rollover than a normal soft top setup. You will have some problem at the rear Curtain area and maybe near the top corners of the B and C Pillars, because of the different shape of the curvature, but you could add some metal to take care of those things. CIVI Soft Top Hummers have pieces that are added to the windshield frame to make each top corner more Square and maybe you could do something like that for the B and C Piller corners. That leaves the rear curtain and those support tubes that extend back. I gave up at that point and went for a Four Man Hard Top with no turet hole. With your fabrication skills, you may be able to make some sort of Hard rear curtain to take care of that area.
