Horn Issue
Typhus Concussion
Atlanta/GA
Okay my horn was working and not isn't. Looking for some advice, here is what I've done so far.
1-checked the grounds that I know of
2-checked horn connections at 25a and 26s
3-checked the brush control, good
4- replace horn button
5- check for continuity from the button to the column
6- checked the horn straight to the battery, good
I'm at a bit of a lose at the moment. Trying to trace the 26a wire but I can't find where it comes into the cab of the truck. What else am I missing?
Sent from my SM-G935V using Tapatalk
Action
1,552
East Tennessee
One horn wire is always hot. The ground wire goes to the horn button. The steering column has a ground wire. When you bush the button, it sends the ground to the horn and it sounds.
Oh, you have to have the light switch turned on. That would be sad if you did all that and all you had to do was turn on the lights....
dilvoy
25
San Francisco, Ca.
There is a small bushing that is located between the horn button electrical connection and the wire connection that exits through the steering column shaft. If it is not there, your horn will not work.
Typhus Concussion
Atlanta/GA
Yes I bought a 24volt electric air horn because the other one sounded like a clown horn. That horn works off of the battery, so I assumed it was a line issue
tage
68
LOS ANGELES / CALIFORNIA
I don't think those ******* SOBs can hear GD thing when they're blasting their music.
Hmmwv horn is on par with the General Lee's Dixie horn. In fact that should be my next upgrade on the m1038. :naner:
Typhus Concussion
Atlanta/GA
Dilvoy, I have the brass bushing and the rubber bushing, maybe I'm not putting Them back together properly. I don't see a picture with both bushingso together, do you have one?
