How do i turn my fuel pump up?
Stretch44875
Super Jr. Moderator
31
Tiro, Ohio
Seach button is on the top of every page.
And if it is a 5 ton LDS motor, the pump is already turned up, any more would be too hot.
wreckerman893
Possum Connoisseur
15,644
2,127
I'm not a diesel doctor but I'll give you the short version of doing "Cincinatti Tuneups" on diesel engines (Cincinatti is where they used to make Vise Grips....old time truck drivers used to clamp off the return fuel line to put more diesel to the engine ergo the name).
More fuel will get you more power but it will also get you holes burned in the pistons and major damage if you run it hard in a pull. You also need to make sure you are getting plenty of air and that the exhaust is free flowing.
That is why you need the pyrometer....to let you know when to back off the throttle.
If you have a feel for diesel engines you can actually feel the truck pull better when you back off the fuel.
Diesel engines, especially military ones, are tough but they can still be destroyed by neglect or abuse.
M54a2weasel
Portland/Oregon
I do not tow with my truck it is just for show and driving around town. The truck is a mulit fuel. I am just looking for a little more pull when i am at a stop light and on hills. Unless you guys have any other ideas on how to get more power or speed.?
Floridianson
2,521
Interlachen Fl.
I think I would look at the TM trouble shooting the 465 and check that the fuel and boost are correct for factory specs. If you wish to raise a small amount that will be fine. What you are looking for are the boost #'s from 1600/2000rpm controlled by droop screw or smoke cam as by which IP you have then check boost 2000/2600 by the main fuel adjustment. You will also be checking fuel pressure by way of in tank and IP fuel pump at full rpm.
We are talking more fuel not speed if you leave Gov at 2600 or set Gov. to 2850/2900
Floridianson
2,521
Interlachen Fl.
I know what motor he has and he needs to check the numbers first inless in you wisdom you can read the boost numbers from your house.
jdknech
Jeffersonville, Indiana
"lol, i am saying, leave it alone, all i can read from my home is your lame posts.
Drive it and enjoy, if it ain't broke don't fix it"
everyone is entitled to do what ever they want to there trucks! if you want to paint it pink camo (like my girlfriend:twisted:) and drive it to makeup shows, that's your choice! i turned up my multi A LOT and have had no problems, just use your head when you drive and you'll be ok...
M543A2
15
Warsaw, Indiana
As I have said in reply to many of these kind of posts, we own two deuces and two five tons that are highly turned up. We have been using them in farm service this way for years with no problem. With at least a boost gauge, and at best also a pyrometer, you have no problem if you drive wisely. I definitely do not agree with the stated come apart reputation from my experience, and others in my community. These same engines are serving at 80 to 90 percent and more power in White farm tractors hour after hour in harsh conditions. They have been very dependable for us. I think the biggest cause of the come apart name is shoddy building and military drivers that did not give a darn about how they drove them, then we get them already damaged. If you have the good head gaskets, go for it with good driving sense.
Regards Marti
hughscpa
Coffeen, IL
Hey JDKNECH, watch the pink camo thing. That's how I got to get my bobbed one paid for.:mrgreen: The right funding source and I'll paint it whatever color they want as long as I can drive them. This is a great hobby and I love hearing all the comments. A question on this subject though is my one duece with 395's on it is kind of a dog on the open road compared to the bobbed one. Top speed about 58 with the quad 50's in the back. Is that about right? It has the D turbo on it. Thanks.
Billy Bobbed
13
Terre Haute,Indiana
I would not attempt to turn up the fuel with out a pyrometer.And knowing the egt danger zones.For now Im keeping mine under 1200,but I here guys going up and over 1300.
