How would truck lose air pressure in the engine intake?
SUPERSPORT
Ohio
I'm pretty sure the cylinder I marked with the red dot is the one that engages front axle. Correct?
Is this what I should try knocking on or is there some other valve you were talking about?
simp5782
Feo, Fuerte y Formal
9,513
Mason, TN
The one to the top right of it. It controls the air from the switch into the transfer case
Sent from my SM-G860P using Tapatalk
simp5782
9,513
Mason, TN
SUPERSPORT
Ohio
Finally had time to get on computer so I could look at TMs.
TM 9-2320-272-10 and TM 9-2320-272-23-1 page 0003-10.
Way I read it the top one prevents t-case from being shifted while in gear and one I put red dot on is the front wheel drive.
Jericho
72
Landaff NH
Transfer case?air hiss
THE real question is do they have air supplied to them . If your still hearing the noise from the intake its because you have a valve that is pressure supplied leaking air into the intake manifold air intake not the cylinder head. Suggest you take a look at the Transfer case linear actuator, its on the front of the transfer case and has a lever arm that contacts the front wheel drive shift lever, when the shaft moves back and forth it actuates the arm and shifts air from direction side to side , as you actuate the low range shift lever in the cab observe the linkage and its movement in relation to the lever arm and linear valve, Heres a snap of what I found when I noticed it wasn,t functioning properly, If I can post it , the end of the valve where the cam was housed was full of Exfoliated aluminum , not even working and bypassing air! Had moisture in the tanks and lines, Opened bleeders at passenger and using a simple air line filter and a bit of airline alcohol. injected it into the tanks, long story short , no more air hissing in Intake plenum P.N on valve is LSC 3270-S26022-1
Jericho
72
Landaff NH
Well ,cant figure out the photo posting transfer, Pictures are in my photo album under big ugly green trucks you cant miss them
Jericho
72
Landaff NH
Thanks Simp. trying to get P2P to work, Not wanting to steal a thread but did you do a thread on your intake upgrade, Specificly the P.N. for the 8 inch snorkel head? and lastly, How has the bump in fuel worked out , reliability, increase in performance ? thanks andy at Jetoneusaf@gmail.com
simp5782
9,513
Mason, TN
I emailed you the pictures and information on the intake. As far as my pump. It is pretty beastly with the dual fuel line kit it will jump out of its own shoes with the slight push of the throttle. My mileage is in my 30,000 mile OTR report http://www.steelsoldiers.com/showthread.php?162662-M923A1-30-000mile-OTR-Report
