I have joined the club ! And yes I have lost my mine !
1951M1078
Allen, it came from Michigan / Ebay . Just put in 28" x 72" RV door. Look to be going for $200+- plus shipping ,new. Think I paid $100+ for shipping. Didn't wand to go with used/take-out. Had key's and screen door also.
1951M1078
Need some parts and a U joint puller so I started work on my support vehicle's . Its a 1980 Honda CT 110. Was not running but have worked through that.
We will have two a his and hers thing. Will work out a bracket also.
As for the truck I'm having two new driveshafts made. Mine were, ? junk !
1951M1078
I'm keeping it. You just need to get one.
Think it will be like a spare tire. You only will need it when you don't have it !!!!
Other things needed will be a 1 1/4" wrench and maybe a socket.( I had better luck with a wrench) A 8 MM 6 point and a 5/16" 6 point , deep socked for the Zerk's . Pull them before you start pressing.
Two tall jack stands or some straps to hold the shaft's up. (The slip end is heavy )
Can of Blast-it (use the night before) on the joints.
Can't remember the cap bolt size but will need a socket or wrench for them. Think they are 1/2 "?
When I put it back together I will coat the cups and the sockets with a non hardening sealer to keep the rust out. Mine were very rusted. Made some very loud noises when they came free ! ( Like being shot at ) LOL
Also found taking the axle end apart in the front made it easier to do the transfer case end. In the rear it was easier to do the axle end first also. ( my bad I didn't look at the manual first maybe it tells you what is first ? )
So now their at the shop and I will soon get a call with what it will cost ? Also found out you can't go to the next size larger slip joint with out going to the next size larger U Joints. Bummer !
I was also asked about the angle of the joints. Are their wedges to help with that ? Was told it would help with making the shaft last longer ?
wandering neurons
Fair enough, Always good to have the necessary tools. Just had to try. What brand/model did you get, and where?
Also, thanks for the info on the procedures!
1951M1078
Also go the repair cost for the two drive shafts, $1300. Looks like my truck just went up in price ? LOL
1951M1078
All cleaned up and ready for the new shafts !
Also found two more things for the tool box. A 8mm x 1.0 tap and die.
1951M1078
Great news ! I'm going to get shafted tomorrow ,in more ways than one way. LOL
Can't wait to see and feel how is rides with new shafts.
1951M1078
Think the color is up to you.
The new shafts are in. Just one word .
"WOW"
Next will be some newer tires. The 03,05 and 06's are a little tired. And they are all a different O.D.! But I need to save up for that.
Saturday I will do some welding on the pullout landing. Get the slide's installed and start the pull out.
pontiac62
"WOW"
View attachment 722919View attachment 722920
Go for a test run?
Man of few words
M1081 LVAD
