In Dash fuse holder?
Warren Lovell
SAN DIEGO, CA
Just assembling my dash and noticed it had a 30 amp fuse holder mounted to the left of the steering column. Does anyone else have this? It has a screw on top that you can slide the fuse into. I don't know what it was attached to since the wire had broken free, but it looks like it matches a wire from the headlight harness.
Warren Lovell
SAN DIEGO, CA
I haven't bolted the dash completely in...I was sort of waiting for someone to go out to their truck and remove their bolts and measure them for me so I could finish this article!
If all else failed, I'll run a tap thru it and install a larger bolt.
Boatcarpenter
Marlborough, NH
As I said in the other dash bolt thread, I pulled one of mine and a 1/4 20 fit. Sometimes I run a die over bolts I use to clean them up so they are the true NC and they work better. I just know there are different thread forms so cleaning them up seems to help.
1,158
So what circuit is the fuse for? I know one of you guys knows.................
1,824
After market or unot add on! It's not stock for anything normally on a deuce. Are you referring to the upper door hinge bolts for the thread pitch question?
