Installing m35 lockout hubs.
Madfarmersson
Stratton Colorado
I know there are several threads about lockout hubs for m35's,
But I am not seeing any on how to install them, I have never tore in
to any lockout hubs before and do not know a thing about them.
I think I may get a set but just want to see how hard they are to install
I will be driving it about 130 miles to a parade in a few weeks so if I get them
I want to install them before I go.
Madfarmersson.:lost:
4,631
I'll make a video of it and time how fast I can change out a set. Who want's to provide a set of hubs for this? :mrgreen:
houdel
Chase, MI
The lockout hubs ship and install as an assembly. The only "loose" parts are the bolts and gaskets. You might want to
consider replacing the gaskets when you install the hubs. This is about the easiest thing you can do on a Deuce. Takes
from 5 to 15 minutes per side depending on your mechanical aptitude & how organized your toolbox is.
two.fiveM35
11
Victoria , Texas
I am interested and have been tossing around the idea also. Madfarmersson keep us updated if you decide to do it. I'd like to know how much the ride improves.
dabtl
Denton, Texas
I got the lockouts a couple of years ago from jatonka, the AVM kind.
When I pulled the stock hubs on one of the deuces I was surprised to find no gaskets. I put the gaskets JT sent on both deuces and never looked back.
Well worth the expense. I was shocked at how easy the change out was and how quickly.
hndrsonj
Senior Chief/Moderator
361
Cheyenne, WY
The lockout hubs ship and install as an assembly. The only "loose" parts are the bolts and gaskets. QUOTE]
My Selectros are two piece. There is the hub and about an inch thick spacer with 2 gaskets per side.
cyruscat
Arkansas
Installed AVMs in about half an hour. Got torque values from TM.
Big improvement in steering effort, on my truck it cut steering wheel turning force at low speed in half!
Smoother and quieter running on highway. Mileage? Who knows, I run such a mixture of WMO and other stuff I can't really compare.
Imagine it cuts down the spinning mass weight of front axles, drive shaft and transfer case by about 500 lbs. or more
4,631
How do you get hold of a particular person on this site? I cant seem to figure it out. I seem to get into trouble on my punctuation.
You would PM the person in question. You can do that by clicking on the users screen name and selecting private message.
1,814
At the top left, click on "My Profile" Once you do that there will be a menu that runs along the left side of the page. Click on "Send Private Message" and go from there.
