todds112
- 5
- 18
- Teton Valley, ID
I think I need the rubber fuel return hose that goes from the fuel filters down to the frame and connects to the copper line.
It's leaking pretty good. I took the lower connection apart, cleaned and put it back together, but it still leaks. I can't tell for sure where it's leaking from. It doesn't leak when it sits and idles, but if I drive it, there is fuel all over the area of the connection. There will be fuel above the connection and leaking down dripping off the connection itself. I'm assuming it's spraying somewhat.
I have found listings for the input rubber hose, but haven't found the hose I think I need. Is this part available, or can an auto parts place make one up?
