70deuce
- 122
- 43
- Franktown, CO
Finally broke down and went in to the left rear hub on my M818 to see what was leaking. Nasty mess on the outside of the drum noted before the teardown. For now just took the brake drum off and it came off surprisingly easy. Pretty wet near the inner seal and lots of gear oil in the cavity behind the drive flange. Tomorrow hub is coming off to see which one of the seals is the culprit. Brake shoes luckily were dry. More pics to follow. My Ingersoll Rand Thunder gun and that GL compressor did all the work on the lug nuts. Worked well.
