LMTV Air Conditioner
mkcoen
382
Spring Branch, TX
I have a m1078
Can't help you there. I've got a couple of pulleys for the C7 (which doesn't help me either). I haven't seen a loose one for the 3116. I'm going to see if I can't modify the one I have to work but it's not a direct bolt in.
mkcoen
382
Spring Branch, TX
So you have a pulley that will work on A1?
Yes. Scottmandu has them.
From what I could tell in the schematic for the 3116 the pulley is on something that sticks out from the engine like a block or "pier" with the pulley on the very end. This one looks like it just bolts on to the head or something else but more direct to the engine. Since I don't have the drawings for the A1 AC system can't speak directly as to how it mounts. And as I don't have a NSN or P/N with it I cannot verify what exactly this fits.
FloridaAKM
395
Gainesville, Florida
The picture of the parachute tiedown cover, what is that for? My truck is missing one of them & I need to replace it! A/C system, that is a ways off for me with no window & air system problems!
mkcoen
382
Spring Branch, TX
View attachment 625634View attachment 625632View attachment 625633
Okay after reviewing the schematic in Overdrive's thread (http://www.steelsoldiers.com/showth...Compressor-Mounting-Brackets-Install-Write-Up) it looks like this is the correct pulley for the 3116 after all. I couldn't get a very large version of the pic but now that I have one in hand and look at it again it does appear to be the one I, and so many others, need. Sorry for the confusion, jumping to conclusions, etc, etc. But the good news is they're out there.
InMemoryofRex
Longmont CO
FMTV / LMTV Air Conditioning Parts for C-7 engine
I just put together my notes in regards to the AC install on my FMTV with the C-7 engine. I hope you will find this useful.
[FONT=Liberation Sans, sans-serif]FMTV / LMTV Air Conditioning Parts for C-7 engine:[/FONT]​
If you can get a hold of it, there is a complete kit available. Currently on E-bay for $ 3K.
Red Dot Corporation RD-6-5281-0 Rev B
http://www.ebay.com/itm/FMTV-Series...r-Conditioning-Installation-Kit-/282019184489
It contains the following parts:
[h=1]Compressor Bracket #1 (Green) :[/h]
  • MFR-0HMH8
  • OFW39
  • NSN 2590015281670
  • BAE TV040127
[h=1]Compressor Bracket # 2 (Black):[/h]
  • OFW39-TV 050009
  • MFR-0HMH8
http://www.ebay.com/itm/MILITARY-LM...ash=item33b1491de4:g:cAwAAOSwKtVWt2TL&vxp=mtr
[h=1]Seltec Zexel TM-21HX 8-Groove 24v Clutch Compressor:[/h]
  • NSN 4310-01-562-3904
  • Part # 107611300C
  • NIIN 015274921
  • Compressor: NSN-4310015274921 BAE Part #TV040084 Red Dot Part # RD-5-10427-0
http://www.ebay.com/itm/SELTEC-Zexe...ck-/331871885046?_trksid=p2141725.m3641.l6368
[h=1]Compressor Clutch (if not included with compressor):[/h]Seltec TM15/16 2Gr A/C Clutch 24V - Red Dot 75R0274 / RD-5-10232-0P
  • MFR-62534
  • RD-3-1669-0
  • 75R0274
[h=1]High Capacity Receiver Drier:[/h]
  • 19207SOCN125O5732
  • MFR-62534
  • RD3123522
  • 4130-01-567-7529
  • RD-3-12352-2P or RD-3-12352-2
  • 64B97/RD-5-12182-0
  • Parker Part #: PH-08853500
  • Red-Dot RD-5-11435-0
E-Bay $ 18
http://www.ebay.com/itm/111587594261?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
[h=1]Bracket Assembly - Receiver Drier - $ 10 E-bay, none available at the moment.[/h]
  • RD-4220-0P
  • Red Dot 74R7220
Not crucial, you can build your own or use a generic one.
[h=1]T/A 90 Deg Comp Suction:[/h]
  • RD-2-4991-O
    GENERIC
[h=1]Compressor Serpentine Belt, 55 Inch:[/h]
  • RD-5-11481-0
  • 47-0559
  • BAE #TV040076-001
  • 47-0559 3030-01-528-1458
  • RD5114810
  • TV040076
  • NIIN: 015281458
[h=1]Red Dot Pulleys: None available on E-bay at the moment.[/h]
  • #1 Part Number 12505708
    #2 Red Dot Part Number RD-3-1240 Red Dot RD-3-1240
[h=1]Diagnostic Module:[/h]
  • A/C System Protection & Diagnostics: RD-6-5281-0 RD652810
  • Red Dot Protecht Module 24V – RD-6-5281-0P NSN 4120-01-532-4474
$ 305 from
http://www.partdeal.com/red-dot-protecht-module-24v-rd-6-5281-0p.html
[h=1]A/C Condenser:[/h]7H15
http://www.ebay.com/itm/281996247169?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
[h=1]A/C Heater Assembly[/h]http://www.ebay.com/itm/Lmtv-Fmtv-l...on-M1078-M1083-M1088-M998-M1151-/112017778369
NSN 112017778369
[h=1]Misc. Parts:[/h]Fan: RD-5-1597-1
Hose: Rd-2-5401-0
Hose: RD-2-4987-0 No. 6 Drier/TXV
Hose: RD-2-4985-0 No. 6 Cond/Drier
Hose: RD-2-4988-0 No. 8 Comp/Cond
Please let me know if you have any other information. With best wishes to all, Toby
