Loose Ground Wire Passenger Side Engine Harness
Tow4
671
Orlando, FL
I need help Identifying a loose wire on my M1028A2. It looks like a ground wire to me and I don't see any obvious place it should be attached. The wire is coming out of the passenger side engine harness near the firewall right over the rear most injector.
I checked wiring diagrams in TM 9-2320-289-20 and the engine wiring harness replacement section in TM 9-2320-289-34. Page 4-80 in the -34 TM has a picture of the harness but does not show this wire coming out.
If somebody can have a look under the hood and tell me where it goes I would appreciate it.
doghead
4 Star General /Moderator
1,191
NY
What color is it?
doghead
1,191
NY
I looked at my truck and it goes to the middle of the bottom buss bar(ground).
It looked black, but I was looking at it from infront of the truck.
doghead
1,191
NY
Looking at the schematics, it looks to be the ground wire for the glow plug temp sensor for the glow plug controller card.
Warthog
241
OKC, OK
Just checked my M1009 and mine also attaches to the Ground Buss Bar behind the rear battery
Does you GP system work?
Looking thru the wiring diagrams, it looks like the GP Controller Ground. It might be the Diagnostic port but not likely. I will have to verify that later.
doghead
1,191
NY
And you are supposed to be faster now that your a supermoderator...:doghead:
BTW, Nice highlighted schematic. That beats my fast reply.
Tow4
671
Orlando, FL
After wiping the dirt off it is black and the glow plug system does work. The glow plugs cycle once for about 2 seconds after the engine starts and I can see the voltmeter drop. I can also hear it cycle before I start the engine and there's no exhaust smoke after it starts (of course it's 85 degrees F, so it may not matter if they work).
Thanks for the quick replys. :beer:
erniemigi
Amelia, ohio
Not wanting to step on any ones toes or say your wrong but need to ask this question to Tow4, do you have a ground wire already mounted near the wheel well area, just in between the front and rear battery down low, just asking cause i have one that runs to that area that looks just like that
Tow4
671
Orlando, FL
Can you post a picture of it?
