m 925 won't start
SneakerZed
Casper, WY
The truck turns over just fine but it does not fire. It ran just fine and fired right up a month ago. I am no diesel guru but it seems like it is getting no fuel. there is a primer pump but when i use it ther is no resistance no matter how many times it is pumped. could it have air in the fuel line? if so how do i get it out? f it defines how to do this in one of the manuals, a pointer to the correct one would be great.
SneakerZed
Casper, WY
i just spoke with my son and said he used the emergency shutoff to stop it. i saw on another post how to manually rest that and i will do that shortly.
elkhtr
Stanwood, Wa.
Did you have the bleeder valve open when you were trying the primer pump? If that was closed, it will pull out and it should not be able to be pushed back until you crack the bleeder. Hopefully you can just shove the fuel shutoff valve back over and be on your way.
