M1008 Fuel Return Line Location
Efituned
Midland, Ga
I swapped the 6.2 for a gas engine and I have been having some fuel vapor lock issues. Looking to install an electric fuel pump with regulator. I looked for a return line going to the fuel tank when I pulled the 6.2 out and I couldn't find one. Does one exist on these Cucv's?
hodgeb
Rapid City, SD
IIRC there are two of them on a 6.2 detroit vehicle - they're metal and run the length of the vehicle to the tank, above and below the larger diameter fuel feed line. At least that's what I think they are - they're present on both my 6.2 vehicles, and fuel comes out when they break. :)
Efituned
Midland, Ga
Off topic but how do you get power to the gas motor?
I used some wiring diagrams, that I found on this forum, to see what needed power in the cab, like fuse box. Then once the inside was powered, I found switched ignition and constant power outputs from the firewall harness connection.
I will look this afternoon and see what I can find. I saw a line coming from the fuel tank about 8" out and it was capped off. Either this line is a vent or the return line.
phil2968
17
Lakeland, Florida
On Recovry4x4's M1010 that capped line is a fuel pick up for a generator if the truck had be a "contact maintenance truck". It worked well for the engine pick up. Also worked on Seddmon's contact maintenance truck on his way home from the last SSGR.
I guess you have a M1008? I would think the lines would be the same.
