m1008 turn signals
jwasjp
nj
jst cut out the diode to get my horn to work and now it works great. but now i jst found out that wen i use my left turn signal the right one goes on too. and also wen i turn on my headlights and try to use my left signal it does not blink it just stays frozen. anyone know how to fix?
Cucvnut
75
Carver, Oregon
i had the blinker issue also it was not grounding right i had to wiggle the bulb in the plug and it fixed it. It was the bulb in the grill that was causing the issue
mikelee
montrose,michigan
Found that the ground also behind rear tail lights are most of the time corroded that screw to sheet metal replace ends..And ALWAYS clean fuse holders this will save you some headaches believe me... I am sure everyone that owns one of these will tell you the same...Nothing like tracking a problem only to find it where you started. and good luck:ditto:
1tonfun
owosso/mi
on with the lights/ignition/ or just on all the time?
if theyre just on with the ignition, trying shifting to low range, see if they stay on
jwasjp
nj
i have it in park with the service light switch on, no ignition and they go out wen i switch into reverse or any other gear
1tonfun
owosso/mi
id say , still a ground problem, or your green wire is shorted to a brown wire ( back up lamps green, running lights brown)
