m1009 Fuel pump leak
frankieg
carroll ia
It looks my my fuel lift pump is leaking. It is very close to the crossmember. Is it replacable without removing the right side motor mount or jacking up the engine. Would it be better to install a electric pump and by-pass the mechanical one?
Do these pumps ever leak externally at the middle seam? If they don't leak there - maybe it is just a fuel line
thanks for the help in advance
CUCV85
central/ny
:grd: YES agreed just replace the feed lift pump, make sure to have the push rod in the right place with some axle grease. I paid 15.00 for mine from Advance Auto Parts 2 years ago.
By the way it takes 1 hour to take off and replace with a new one. Easy Job.
Warthog
245
OKC, OK
