m1010 white smoke wont stay running
dmetalmiki
2,026
London England
On a diesel engine the cause of white smoke can indicate incorrect timing. And the most common cause in addition is water leaking past the head gasket, or (hopefully not) a crack in the engine block.
You might also check the antifreeze and or any additives that might have created acid in the cooling system.
A good flush out and then 'appropriate additives' commonly found for slight leakage could stop the problem.
richingalveston
120
galveston/Texas
a bad IP can do the same thing so start there. it is your timing source for the motor and your fuel delivery for which it sounds like you have problem with both.
if it starts at all then you normally have some glow plugs working, maybe not all. you also may have a bad controller not letting them glow long enough or after glow. There is a temp sensor to check for this and trouble shooting instructions for the cards.
check glow plugs and solenoid. then fuel before and after IP, No fuel at iP then start working your way back until you find fuel.
a bad fuel pump can produce the same symptoms.
Have no signs of water leaking water in oil or oil in water have fuel to injector pump but sure how much i should have at injectors do have some but not a spray glow plugs are only 6 months old but didnt check them
Drock
11
Eatonton GA
I would put a temporary piece of clear hose in place of the I.P. return line. This will show if your getting air into the system.
Hasdrubal
Vancouver BC
I had a Carter lift pump fail after only 11 months. You could see fuel leaking from around the sides where the lower metal section wraps around the upper aluminum part. The AC Delco replacement has been going for 4 1/2 years now.
