Trailfinder
- 1
- 8
- Springfield,VA
Does anyone know where I can find side and end racks for a M101A1 trailer? Thanks.
Thanks for the info on the wood for the bows. I was just going to do a search on this when I saw your post.CGarbee said:If you find the metal hardware, I have the dimensions for all the wood pieces on my website...
www.garbee.net/~cabell -- look on the index for "bedwood"
I'm going by memory (I'm at the office, my trailers are at home...), but the height of th sides are different, so at the very least you'd have to trim the M105 side posts. In addition, the M101 has rear gates so the uprights on the back corners have hinges instead of "hooks", also you need the plate with the latch for the center of each gate...builder77 said:Anyone know if M105 metal pieces will work with a M101? I know the metal bows can be adjusted for width to fit either by just bolting into the different holes. I am really curious about if the sides metal will work though as I have all those M105 sides, and there are some with bad wood.
