m101a2 with no tires
angrypuppy
wa
*edited to avoid rules violation* m101a2's with no tires. If I were to get one of these how do I find wheels and tires?
ultim8gamr
Napa Valley, CA
order wheels and tires for a chevy 1 ton from the 80s. Chevy 8 lug 16" wheels. The tires that came on my M101a2's were brand new Cooper Discoverer A/T 235/65R16
goodguyzy
13
medford oregon
i have a few extra, the thing that really torques me is i bid on a trailer there and then i get out bid when there are 20 other trailers that are the same with no bids. no big deal if i was retired but hard to bid on another when you work construction. so if your coming up from napa, i live 2 miles off the freeway and you can pick up a few if you want
thank you, thank you so much
angrypuppy
wa
angrypuppy
wa
Ultim8gamr,
Thanks for you reply. So is it the 8 llug 6.5 inch pattern? I can't believe I'm having tis much trouble figuring it out.
blybrook
Fairbanks, AK
Yes it is an 8 on 6.5 lug pattern. Found on pre-99 fords; then older dodges and chevy's. I personally use the Ford rims so that they match the pulling truck.
A chevy wheel will be a better fit around the hub as the ford rim is a larger center hole.
See this thread for additional details.
HTH
Bill
