panzerwillie
- 104
- 43
- miami florida
This not just to the M1031 guys as all Chevy CUCV should be the same, so i have had this M1031 for about 2 years is fully loaded with tools that i use on Sundays to do maintenance on some MV's , its all factory except new batteries still 24/12 Volt system , so driving home today as i was getting near HQ it started raining hard so i had the lights on and wipers 2 blocks from home i turn the blower motor as it was getting a little foggy so the GEN light on the left flash on and it stop running , the only thing i had was head lights lucky me i roll in to my drive way, flick key back of and on nothing all dead, waited few minutes for the rain to get lite, check all fuses , everything was good work key back and forward nothing , only thing i had was head lights, check where i believe the vehicle gets 12 volts and it had over 13 volts pull all fuses out with key on nothing wiggle the wires on fuses box nothing check all fusible links for any sign of heat but all was normal, check for 24 volts all good could not find anything wrong , so when back in the cab and turn the key all back on fire right up and drove in to the garage try to duplicate the load but would not do anything , check both 24 and 12 v and it all was good. go figure that its like it pot a a breaker and when it cool down is back on , any info on this would be a great help........
willie
willie
