m116 A2 trailer
flyfishrelease
York, Pa
Anyone renforce the roof with plywood or equivalent. I'm thinking to stiffen the roof to prevent the tarp from sagging with rain water or snow.
mep 003a
m116 A2
KsM715
142
St George Ks
Ive seen several trailers that way. Just make sure to round off the edges and corners or it will wear thru rather quik.
OLDCHEV4X4
Glenmoore PA
I bolted down 5 pieces of 3/4" lath with some 1/4" flat head screws. The water still pools a little. Next time I will use 6 or 7 pieces. I rounded all the corners generously with the belt sander.
I knew it was still a problem when I saw birds using it as a bird bath.
flyfishrelease
York, Pa
Thanks, slats is a good idea. I think plywood will rot faster, maybe down the road when the tarp is no good, a more durable roof with plywood covered with something like ice melt roofing is the way. Don't plan to haul the gen. anywhere so a more durable roof might be a solution.
Happyland1410
Ada, Oklahoma
rosco
32
Delta Junction, Alaska
I do have tarps, both on the 116 & 101's. I took a 2x6 and cut small notches in it @ the bows, a small 45* angle on the top outside corners, and turn that on edge, between the tarp and bows. I just leave it there. It keeps the puddles out and is roadworthy.
simpleserf
Sherman, NY
The gentleman I bought my m116a2 from used a 4x8 sheet of pink foam insulation with the edges rounded. I didn't take this piece due to the size of it vs the size of my shortbox f-150.
quickfarms
25
Orange Junction, CA
I have not found a tarp for my m116a2 yet so I used polycarbonate corrugated roofing panels to provide some protection for now. You would probably need some type of trim on the front and back edges to protect the tarp but this should provide support and would not rot.
Here is a link to my thread with more details:
http://www.steelsoldiers.com/auxiliary-equipment/93718-mep-002a-m116a2-cover.html#post1200663
That is nice
Paint it OD and make canvas side flaps
