gem1410
- 42
- 28
- TOMS RIVER NJ 08527
On my m35a2 the turn signals do not flash--when i turn on the signal the bulbs outside light but no flash--the light on the turn signal does not glow--when i disconnect the wiring to the fender mounted flasher the turn signal light does light--i have tried running ground wires from the battery to both the turn signal and flasher ground with no results--the light switch is the new push button type--tried a different turn signal assembly and a different flasher with same results--anyone have any ideas??--thanks george
