M35A2
How many times do you have to try before your deuce starts? mine did on the frist try but now it takes 3 to 4 trys before it takes off do i need to adjust something i moved from Co to Tx so i dont know if moving from all most 2 miles up to sea level has any thig to do with it Thanks
tie6044
49
Blaine, MN
I have some that as soon as my finger makes contact with the button they fire up and I also have a couple that crank over for a bit and sometimes die after the initial startup.
CCATLETT1984
Saint Clair Shores, MI
Is your truck a turbo? You may need to turn up the fuel a bit and possibly change the timing.
jim-m35a2
Michigan
First thing I checked when mine did that was the in-tank fuel pump. The in-tank fuel pump was dead and replaced it with an inline pump from NAPA. Hooked it up and ran it for a minute or two, hit the starter and if fired up on the first try.
Jim
________
Alaska Dispensaries
