M37 Weapons Brush truck
- 0
- 0
- Salisbury, NC
I have a 1954 M37 with gas engine that was converted to a brush truck for a local fire department. The oil pressure has dropped and I did find gas in the oil. It has an electric fuel pump and I have put a pressure regulator on the line to keep at 4.5 psi. After a change of filter and new 30 wt oil the pressure did the same thing, ran at 40 and then dropped to 2-3 after only 22 miles. Any ideas as to where the gas is entering the system? I saw above that there is a booster pump seal but do not know if this applies to the gas engine models.
