M819
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
So I am waiting to hear back from a guy about an m819. This is the one with the triple section Austin-Western boom? Ron, how much does yours weigh? If it isn't good enough to save, still need a Tcase?
gimpyrobb
27,785
747
Cincy Ohio
Also, If the truck turns out to be just a parts truck, could I take the "manual" section of the boom and put it on my m62 as is? Or would I need the whole boom from the 819?
Fresno, Ca
Re: RE: M819
You will need both inner booms from the M819 and use those to replace the inner boom on the M62. The M189 has a swivel motor rather than the two rams that the M62 uses to swivel with. I would try to replace the whole thing from the deck up. The M819 lacks the storage boxes that the M62 has. The M819 was not designed to carry all the recovery stuff like the M62.
gimpyrobb
27,785
747
Cincy Ohio
RE: Re: RE: M819
So do we think its possible to pull the whole "turret" off of one and put on the other? Gears the assembly(boom) turns on the same?
73m819
314
gainesville, ga.
RE: Re: RE: M819
i dont know if the swap would be a bolt up or not, though i dont see why not, at least you could still use the 26",3 part boom, that should be a bolt up deal, im still looking for a t case, at least the price of one, money is tight here at the moment
gimpyrobb
27,785
747
Cincy Ohio
RE: Re: RE: M819
Well, I have found out the truck is not salvageable. I am now going to focus on trying to get the boom. Anyone know what needs to be unbolted to remove the inner booms? I may hve to just take all 3 sections, but would like to cut down on the weight for the drive home.
73m819
314
gainesville, ga.
RE: Re: RE: M819
to remove the boom , pull the two pins (pivoit and boom hoist ) undo the hoist and extend cyl. hyd. lines, and the work light wire, it would be easer to remove and reinstall the three section boom as a unit then just the two outer sections (this could be a real hassel)
1,814
RE: Re: RE: M819
I have to say that the M62 with the 819 boom and shipper is a way cool idea. Hey Ron, does that worklight wire go through the swivel valve?
gimpyrobb
27,785
747
Cincy Ohio
RE: Re: RE: M819
Yeah, I figured itt would be a pain to get the inside section out. I will probably just take the whole thing.
73m819
314
gainesville, ga.
the wire does go though the hyd. swivel, though mine has been by-passed with a wire comming up behind the swivel, in fact at the ga. rally, this is what i had to connect after i swrung over the front to use the lights for the night operation of the 819
73m819
314
gainesville, ga.
the second and third aw pic would not look to bad on the xm 983, since im going to do a what if , the aw would be about the right year for the xm983
