M925a2 Slow to Start question
tahuyaredrider
Tahuya, Wa
Having starting issues..... Truck runs excellent and shuts down normal. What happens is. Battery switch on and start switch to run, when trying to start with a 5 sec delay motor just cranks. Repeat several times and finally after about 7 or 8 attempts it starts like it should. What part is bad? Fuel shutoff sticking? Stop solenoid sticking? Please help 1991 8.3l 6CTA8.3
For for got to add, Sometimes it starts like it should
thanks. Mike
gavland
Doylestown/Pa
my M295 doesn't like the cold at all so 40 or below I have to use the either button and it still takes a bit of cranking some times.
so if its cold there have you tried the either to see if that helps it out??
