master cylinder question
rottiedog
New Bern, NC
I was told by the guy that installed the 1 ton axle that I should get a 1 ton master cylinder. I was searching the parts stores and it looks like the same part number between the 1 ton and the 1/2 ton.
thanks
Westech
CPL
6,104
211
cow farts, Wisconsin
well there different in the 09 and the 08.... if you install a 08 master in a 09 you will have very touchy brakes and if you install a 09 in a 08 there going to be very soft. the master in the 08 should be a little larger bore to move more fluid for the larger pistons and cylinders. Really if its stopping fine now I would not bother with it. The 09 did not have the rear valve so more fluid will be getting to the rear making it feel more like stock.
rottiedog
New Bern, NC
The rear is locking up easily. There isn't a proportioning valve that I can find.
Would the 08 MC help by sending less to the rear? If I understand what your saying, it should help...
Westech
CPL
6,104
211
no the 09 will send less.. make sure you have the rear shoes set right and not too tight.. ez mistake lot of people make. also brake or rear dif fluid on the shoes will make them lock up like right now and in a hurry.
