Scoobyshep
- 959
- 93
- Florida
meter between pins 8 and 7
Yes I have 0 volts between 8 and 7 while running and the reverse current light is on and offmeter between pins 8 and 7
on and off?Yes I have 0 volts between 8 and 7 while running and the reverse current light is on and off
what do you want the video of?on and off?
can you send a video?
yes i have 0 volts rather the reverse power light is on or offon and off?
ok I follow you now. Next meter chassis to pin 7 and chassis to pin 8yes i have 0 volts rather the reverse power light is on or off
Also 0 for bothok I follow you now. Next meter chassis to pin 7 and chassis to pin 8
ok same thing for K14 pins 5 and 6.Also 0 for both
Yes while running and dc on meterok same thing for K14 pins 5 and 6.
just double checking, youre doing this with the set running and meter on dc right?
5 and 6 not 4 and 5Yes while running and dc on meter
k14 5 and 4 0vdc 4 to ground 27vdc 5 to ground 0 Vdc this is the same with light on or off
My bad checking now5 and 6 not 4 and 5
That is zero as well also checked both to ground same and same with light on and off also there’s nothing connected to those terminals k14 the over voltage relay correct?5 and 6 not 4 and 5
Ok yes I checked the correct one and have 0 also mine has nothing connected to those 2 terminals also checked both to ground and with light on and off all results were 0K14 is the Overload relay
p62h18 goes to pin 6 on the overload protection deviceon K14 find wires P62H18 AND P61A18 what pins are they on ?
K14 hasp62h18 goes to pin 6 on the overload protection device
P61A18 goes to pin 8 on k15 revers power relay
Okay,meter the voltage on those two wiresp62h18 goes to pin 6 on the overload protection device
0 voltsOkay,meter the voltage on those two wires
Sent from my SM-G973U using Tapatalk
