- 18,200
- 27,337
- 113
- Burgkunstadt, Germany
Thats with the AUX still hooked up?
No sir,Thats with the AUX still hooked up?
Is the auxiliary pump still electrically connected?No sir,
The aux tank is not hooked up.
Yes it isIs the auxiliary pump still electrically connected?
All the best, 2PbFeet
Two 12V batteries do work. If you do this much at all, a bench power supply is a lot cheaper. You set the voltage (and/or current), and can test away.What is the best way to test a 24v pump out of the generator? Get 2 batteries? Get a 24v battery?
Also, just browsing in case I need to buy a new pump it likes like they start at about $80. Weren't they really cheap at one time?
Thanks for that. I'll shop for a bench power supply. I'm sure I would have other uses for it as I maintain 2 small tractors and a bunch of other equipment.Two 12V batteries do work. If you do this much at all, a bench power supply is a lot cheaper. You set the voltage (and/or current), and can test away.
Pump prices vary a great deal. With the current uncertainties around import costs, I would anticipate even more variations in prices, so probably a time for even more comparison shopping.
All the best,
2PbFeet
There are off brands, and there are off brands. To me, the risk with "cheap" ones is reliability.Thanks for that. I'll shop for a bench power supply. I'm sure I would have other uses for it as I maintain 2 small tractors and a bunch of other equipment.
It looks like the Facet brand pump runs $80-120 but I can get an off brand for $40. any reason not to get the off brand?
