MEP-831 starting problem
olbucksnort
Bowling Green, VA 22427
MEP -831 will pull start and run. The original and new starter motor act like L70 Yam is a rock . Solenoid engages but Starter Motor can't turn it over; even with pull starter assisting (hard to do , but was worth a try) ???? The battery has 25.6 VDC ????
kendive
Florida
I am not an expert on these things, but when I was having starter issues. I ended finding a bad K2 relay/contactor. Is yours making a clunking noise when trying to start? Try jumping it out to see if it will crank.
Not sure if you saw my thread but here it is when I was having starter issues.
https://www.steelsoldiers.com/showthread.php?181793-831a-Starter-Issues
