MEP004A keeps running at low RPM after it is shut off
Amnon
Raleigh, NC
Went out to run my spare 004A and it took a good 30 seconds to start and get to normal RPM. I then noticed that the voltage was at 120V, but nothing on the frequency meter. Shut it down to try again, but it took it about two minutes to actually shut down. It kept on running a a very low RPM. Finally it did shut down and I restarted it the normal way by holding the start switch up until it reached normal RPM. But the freq. meter showed nothing still, with the volt meter showing 120. I let it run for about 5 minutes, shut it down, and the same story, it kept running at very low RPM for about 2 minutes, and gradually shut down.
Any ideas?
Thanks
Amnon
Scoobyshep
2,249
Florida
Ok so first thing use a multimeter ( or in a pinch a kill-a-watt meter) to read actual frequency ( the onboard meters can go bad)
The slow shutdown sounds to me like the fuel solenoid in the IP is sticking.
A video would probably be helpful in this case.
Ray70
7,127
West greenwich/RI
If you want to verify the fuel solenoid you can untie the safety wire ( assuming it's there ) that holds the lever on the side of the IP in the counter clockwise position. Shut the machine off and throw the lever to the right to manually shut off the IP.
If that kills the machine immediately, there is an issue with either the solenoid itself or the internal linkage is sticking and the solenoid is not able to overcome the resistance quickly.
