Korgoth1
- 2
- 0
- radford, va
I have a 802 that has somehow burnt ground wires 100e (goes from starter ground to tb2 ground) and I believe 100g( goes from tb4 to control box ground) Luckily the insulation on the neighboring wires saved them.
I originally thought that maybe they put 100e on starter Hot terminal, shorting the battery through the wire, but that 100g wire is burnt up too. Any ideas what could have happened?
Some details on machine, It makes power, the generator end looks new. The engine is only running on one cylinder, so I haven't load tested it yet. Once I saw the burnt 100e wire I decided not to run it anymore, and started disassembling it to inspect the harness.
