Leaks leaks leaks everywhere. Rather then try to fix the stuff and freeze my butt off I'll post my questions on the forum
It is a toasty 20f today. I took the truck to run some errands, but first warmed it up in the driveway. Immediately, its leakin fuel and antifreeze from the engine area. I suspect the fuel was coming out of the turbo breather that runs to the crankcase, as that hose was loose. Maybe this was a cold starts thing? I dunno.
Tha antifreeze was coming from various other lose clamps. I was able to tighten those clamps and I'm now all set. Attribute this to just sorting the truck and driving it.
So, I drove the truck around for a couple hours, and return home. Now, I have a couple new fuel leaks, as well as a leak from the front axle output shaft. I'm not sure if that is what it is called.
The fuel leak is from the tank line, near the frame. It is also leaking from the injector pump.
The air tank is also leaking from the valve, but I plan on putting ball valves on anyway.
Too cold to fix this stuff at the moment, but I can source parts at least.
1. Where do I find replacement hard fuel lines? It looks like 3/8 to me, and just turns the corner into the frame where it meets a fitting.
2. The tank is leaking at the top, as you can also see from the picture. Is there a replacement gasket?
3. Any thoughts on the injector pump leak? It I take that line off, is it just like a nut and ferule? The leak is from the line with the cap pulled up.
4. Is there an output shaft seal kit. Is that what its called?
5. I also have a torn front boot, but I have seen other posts on that.
