AMgeneral3945
We setup a M920 for hauling liquid manure on the farm. I put 395/85r20 on the front and it worked well, just had to grind the hubs some. But on the rears I kept the 11.00r24 and had them retreaded with a more aggressive tread. The thing I don't like is the dual 11.00r24 sink in too much in the field. I was wondering if 445/65r22.5 would work well. What kind of rims and where to get? What kind of offset are on the ones I see on 920s. For guys that have put them on do you leave the 3/4" studs or replace them with the 1.125" studs? Lastly how would I figure out weight per axle. The 920 gvwr is 76000. The tank when loaded is 46000 and sits right on the frame. I know this is a lot, any info is greatly appreciated. Thank you.
