MV Addiction filled. Reis the Beast M1078A0 is born
M1078MAN
Just waiting on sealant to rivet it in. Using monobolt 3/16 alum/alum flush break round head water proof rivets.
This is not a standard pop rivet, its aircraft quality
I still need to make the nuke shield for the window
M1078MAN
Looking for unit info. 3884 c/ci
So I have deciphered a little of the mystery...3884 is not a unit designator, it is the last 4 of the NSN assigned to this box..
Full NSN is 5820-00-889-3884.
Anyone have an idea what C/CB might stand for, cant be Center/Center Balance, or could it
Here is a pic of a AN MRC 69V that belonged to the Aussies curtesy of the 104SB I believe
M1078MAN
Thanks to a SS member, we have located the original TM 11-5820-204-15, on order and coming in.
Primarliy COM surplus/equipment
If your interested, google up fairradio.com
Sgt Jiggins
Potato Peeler
I have decent equipment to turn that into a PDF for the wider audience. I could meet you in Bedford for a hand-off.
M1078MAN
Sounds like a great idea, making available to a wider group.
When it gets here, will PM you
M1078MAN
Spent a few finishing up roof rivet sealing,..Roof is done.
finished sealing/installing the patch panel and expanding foam the hack job.
I decided that i am going to redo the box for this swing out [due to measure twice failure ] and move the mis-measure box to another location.
M1078MAN
\\MAIL CALL//
Busy day for mail (US PS, EXFED and U PS)
-MMMMF/FFFFM Renogy connector
-Misc circut breakers
-Solar Panel Mounts
Ordered up an exterior Lpg 16000w hot water heater
Well, spent fri afternoon fitting the new box and marking drilling some holes, I tweaked the design of the swing out door so it would be more water resistant
I also positioned two 100ah deep cycle AGM batteries and made cables with the new hyd 10 ton crimper. I like
Getting the floor ready for new flooring install
Cleaned and sealed several previous exterior side wall holes, just need to make the panels to finish them off
Starting to figure out where everything will go on the inside.
Will post a couple pics later
M1078MAN
More progress
Upper and lower box sealed rivetted and primed. Going to fab up an inner door and trim for the pass through and still need to make the nuke shield for the window.
I think its much improved over old bugger hack job
20200804_082350.jpg20200804_082310.jpgAN-MRC-69 (4)edit.jpgAN-MRC-69 (12) edit.jpg
M1078MAN
HINT: See those two square fold outs on the front, two big ole suction fans sat on the inside of the shelter. Removed
