Need fuel tank photographs please.
Lonesome715
25
Columbus, GA
I did a stupid thing this past weekend. I forgot to look at how the tanks were installed on the deuces at the Hooch. So now I have to ask for photographs so I can make sure I get it installed correctly. I have had this tank off for a while and a couple of the lines were cut and crimped before I got it. I have since had the tank cleaned, rebuilt the fuel pump, replaced the sending unit and got some new webbing. As soon as the paint dries on the tank I am reassembling it and slinging this thing back under the truck. I need to see how everything is hooked up make sure I did not forget something. So, if you do not mind, please post some photographs of your fuel tanks and how all the lines hook up.
Lonesome715
25
Columbus, GA
I posted a response last night but it looks like it did not take.
I cannot view the TMs. Every time I try to open one my computer locks up and I have to restart it.
Lonesome715
25
Columbus, GA
Any help at all hear would be greatly appreciated. I am trying to get this deuce running with a limitted time frame and limitted funds.
swbradley1
Modertator
1,944
Dayton, OH
Just to get it on there should be easy. The fill hole is passenger side front. Center it on the hangers and wait for a picture from someone.
Lonesome715
25
Columbus, GA
Outstanding! Thanks. I want to know what a couple lines were crimped. This was a non running truck when I got it, but I see no reason to damage these lines.
Lonesome715
25
Columbus, GA
What is this capped off hole for? I took the plug out when I took the tank apart, but before i stick it back in I am wondering what purpose it serves.
eagle4g63
35
North/west Indiana
That hole is for the arctic heater set up.........the heater kit supplies a fitting and a pick up tube that would go in there so it's fuel pump can pull fuel for it...............I know that cause I installed the arctic kit on my truck.
Lonesome715
25
Columbus, GA
Thanks, an actual photograph sure does make it easier. I was just bolting the fuel pump down now. Those new shiney fastners sure do look good.
Lonesome715
25
Columbus, GA
Just a thought, the breather line is so small. Is there any reason it would be a bad idea to use the fitting for the artic heater instead? That way I can use bigger tubing.
Lonesome715
25
Columbus, GA
Because mine is damaged so bad, I have to make it longer to reach. Is there any reason I cannot use a rubber hose with hose clamps and a barbed fitting?
Lonesome715
25
Columbus, GA
Nice truck.
I notices some rust on my straps that bolt to the lower brackets. After blasting it away I have very little metal left to run a bolt through. It looks like I am going to have to weld some metal in now. I guess this is not going to be the quick turn around I hoped for.
