I received my "good deal" ring mount and legs today. It has two "slight" demil cuts. It looks like the ring has rotated 2-3 inches since it was cut but the cuts aren't pretty at all. It is now all frozen up. Does anyone have info on how to take this apart? I've got a welder who can weld it up and grind it down. The cuts are 1/2" wide and go across the bottom most of the way. The top half also has cuts up the inside. Are there ball or roller bearings inside? The shaft that the lock handle is on is slightly bent. I can't rotate it very much. Does it pull the pin out as it rotates? Does the pin lock the ring so it won't rotate? I've already talked to the person I got it from and told them it may be heading back their way. Any info/help appreciated.
