Need Help with Oil Filter Identification
SteveKuhn
I'm trying to identify the equipment or engine that this oil filter supports.
  • P/N is SA-15417
  • NSN is 2940-00-364-4956 (covers this one and apparently a bunch of other numbers and mfrs.)
  • filter size is 3 3/4" across and 4 1/4" high
Just can't seem to tie that information to the equipment it's made for. Any help would be appreciated.
Thanks
Steve
rosco
Could that be for the "Military Junior" filter housing? The two numbers for the Junior & Senior were P-51 & P-50 or visa versa. I always got the backwards. For instance the M-211 & the M-37 were two applications. By Purolater. I have them in the shop, I will look later.
SteveKuhn
I got the following cross reference numbers from WBParts. Unfortunately, those numbers don't appear:
2940-00-364-4956 ( C50MH, C-50-MH, CE515, SA15417, P7123, VT2427, Y914-315 ) Master Cross Reference Data
Mfg. Part NumberISCRNVCRNCCHCCMSDSSADCDAC
1031 2 2 5
1031 2 9 5
3892940-146000 2 2 5
4X121 2 2 5
51031 2 2 5
600184 2 9 5
C-50-MH 2 5
C154 2 2 5
C50MH 2 2 5
CE515 2 2 5
D440 2 2 5
K152 2 9 5
P651 2 2 5
P7123 2 2 5
PC31 2 2 5
RC24 2 2 5
SA15417 2 2 3
SA15417 2 2 5
T9 2 2 5
VT2427 2 2 5
Y914-315 2 9 5
Y91L315 2 9 5
2940-00-364-4956 ( C50MH, C-50-MH, CE515, SA15417, P7123, VT2427, Y914-315 ) Characteristics Data
MRCCriteriaCharacteristic
STYL STYLE DESIGNATORA10 CYLINDRICAL W/CONTAINER
ABPM BODY DIAMETER3.688 INCHES NOMINAL
ADAS BODY INSIDE DIAMETERANY ACCEPTABLE
AZTL BODY OVERALL LENGTH4.312 INCHES NOMINAL
MATT MATERIALMETAL CONTAINER/CARTRIDGE COTTON FILTERING MEDIUM
CRXW FILTERING MEDIA DESIGNANY ACCEPTABLE SINGLE FILTERING MEDIA RESPONSE
APGF DESIGN TYPENONREUSABLE
ADNH FILTRATION RATING IN MICRONSNOT RATED
ADNK FLOW DIRECTIONPARALLEL
MEDA MEDIA FOR WHICH DESIGNEDANY ACCEPTABLE
AZKQ TEMP RATINGNOT RATED
ADNP DROP PRESSURENOT RATED
ADNQ DIFFERENTIAL PRESSURENOT RATED
ZZZV III FSC APPLICATION DATALUBRICATING OIL FILTER, ENGINE, NONAIRCRAFT
SR-5 MANUFACTURERS CODE13800
SR-5 DESIGN CONTROL REFERENCESA15417
Parts similar to 2940-00-364-4956: V250C14, C233, 210297R91, PA1712, PF349, HF6521, ARM512, C64, 8-94243270-0
LuckyDog
I tried to see if I could find an APL with that NSN. Don't seem to have access to the correct databases.
If it helps,
The OP's original NSN (2940-00-364-4956) is a replacement for the following NSNs
The PN is still valid, but Uncle Sugar hasn't purchased any since 2008.
4330
00-202-6784
2940
00-255-9860
4330
00-277-5425
2940
00-289-8361
2940
00-328-7610
SteveKuhn
Searching the crossreferenced numbers, I found references to Case and a couple of other tractors, but not the engine. Obviously, it was used in a variety of civilian and military equipment, but it seems that's about as much information as I'm going to get.
Thanks for your help.
Steve
SteveKuhn
"...Could that be for the "Military Junior" filter housing?..."
We took it to the Sussex show and the guesses were indeed Junior, but for a Jeep. That might be it because we also found out that Jeep engines were used in various stationary applications, and that's the general application that these came from (but we don't know what.) Also tracks with 4 cyl tractor engines.
Now we're pursuing that.
Steve
