Need M816 Power Divider
blackdog
us
Does anyone have a "power divider" for the wrecker body on the M816? I don't really know what it is but I need one... :roll:
acetomatoco
How do you know? It is the gearbox which lets you decide to run the crane or the rear winch... it will show up in your 34P
blackdog
us
Because I was told that it is the part that is needed to fix the wrecker body on the Mechanized Museum's M816, it is seized up at about a 15 degree rotation... won't budge!
papercu
33
Baxley, Ga.
M816
Like Ace said, it is a gearbox they may freeze up but if yours is twisted you may have more problems than just it. Might want to take it off and check the rest of the driveline. Not sure where you find a used one but you could check in the Salvage Yard Info section. Good Luck, Wayne
