Mspike
- 4
- 3
- New Braunfels, TX
The sun has got to mine and has broken to a thousand pieces. Any good leads to find a new/like new one?
Same here. I'd like a smaller diameter one as well.The sun has got to mine and has broken to a thousand pieces. Any good leads to find a new/like new one?
I like that! Pretty neat...View attachment 822714
I made some window shades to keep the sun out of my cab. It might look a little like towmater...![]()
Yes, that would be nice and light too. I made mine with 1/4” plywood. I also covered the door windows. Sun light is very hard on our vehicles when they have to sit outside. I put UV block on the tires as well.I like that! Pretty neat...
Something like that could be made out of the plastic stuff that political yard signs are printed on (CoroPlast - corrugated plastic). On that plastic would give the sun shields some insulation value as well.
Mine came in yesterday. Will I need a wheel puller to remove the steering wheel?Grant adapter 4405 Is a 7/8" 36 spline adapter that let's you swap to a standard 3 bolt steering wheel. This will allow you to get a smaller wheel if wanted.
Adapter is found at summit racing or jegs
YesMine came in yesterday. Will I need a wheel puller to remove the steering wheel?
