New to me M1008, lock out hub issue.
Postal0311
Tampa Bay FL
Hello,
I picked up a used M1008, I plan to make it my new daily driver. After using it a couple of days, one day I was stuck in stop and go traffic and I started hearing screeching noises from the vehicle.
I think the issue is from the front right locking hub.
The section I am holding on to in the picture is loose. I've taken that section off and I don't see anything that looks obviously wrong. It will most likely have to come further apart.
Any suggestions or advice?
welpro222
Bellingham, WA
Jack it up, remove tire and check for wheel bearing play or noise when you spin the hub. If your unsure of the history of the vehicle you might as well clean/inspect/repack the bearings, its a maintenance thing anyways.
478
10
Tucson AZ
When I did my bearings I took advantage of the labor and installed new Warn locking hubs. I found missing parts missing from the last time someone was in there. FWIW
