Ferroequinologist
Resident railroad expert
- 4,812
- 748
- 113
- Liberty Hill, SC
Well I picked up this beautiful M931a1 for a former member here last Jan. 9.8 miles on the clock. Very nice truck. Drive shafts disconnected. Warning #1. Got it home and charged the batteries. Starter would just go CLUNK. Warning #2. Tried to bar the engine over. Wouldn't turn in either direction. Warning #3. Started pulling rocker boxes and injectors to see if she is hydrolocked. Number two looks very funny.
So anyway I pulled the head this weekend, and found this. Looks like something got into or was left after rebuild the #2 cylinder. It beat the tar out of it until the piston started to come apart in chunks. There is even a piece of ring in the top of the piston because the side of the piston is so bad. Melted aluminum everywhere. Engine is locked up hard. Worst part about all this, is you have to rotate the engine to take the torque converter off. So I will have to tip the engine onto its side and take the lower end loose to get the rear off. He purchased another 250 to go into it I just have to swap all the parts over.
Thought you guys would like to see the carnage. Some of the piston pieces even made it into the #1 cylinder.
