No Longer Stuck here w/no primary air, safe to drive home?
SirKen
Cocoa Florida
I have secondary air but no primary air with no air leaks to be found. Can't leave it here, do I gamble with only secondary air? Worked fine 8 hours ago and just sitting in the parking lot. Tried starting, turned everything off then started again but still no primary air.
Suprman
659
Stratford/Connecticut
Check your air dryer expello valve. There are 2 valves by the wet tank for primary and secondary air. Check and make sure the 4 petcocks are closed. There are also check valves between the air dryer and tanks that can freeze up. Sometimes you can tap on them and get it free. Is there a difference between parking brake on and off?
ke5eua
40
Baton Rouge (Central), LA
This happened to me on a recovery trip with a 925. Valve stuck open. Scared me as it happened during rush hour in Oklahoma City. Pushed it in and was able to make it the rest of the way with no further issues.
Hope everything works out.
SirKen
Cocoa Florida
I will most definitely review and repair everything mentioned here and I can't thank you all enough.
Home sweet home, maintained air pressure all the way home... finding a new dryer next.
Thank you all again.
1,168
Dryers are something you service, not replace.
