NOOOO, Not another Snorkel
truck7.jpgtruck01.jpgtruck 6.jpgtruck2.jpgtruck3.jpgtruck4.jpgtruck5.jpgtruck9.jpgtruck8.jpgtruck 1.jpgMorning ALL
Just about finished mine. This is what I have left to do: Clamp down "fake" heat sheild. (just for looks) Mount bracket and run brake lines up the snorkel. Then tie them into blue lines that run to the Trans, Transfer Case and front and rear axle. Also planning on installing a pelican box over the fuse box, cutting out the back and sealing it. Notplanning on forging through water, just think it looks COOL.
gnick
what coupler did you use to connect to the air filter housing? i need one of those.
this looks awesome by the way!!
Refuring to the 2nd picture? I welded a peice of 4" electric pipe (EMT) to the housing base. then made moom shape flat medal to fit oval to round on back side
