- 4,812
- 1,256
- 113
- Gaithersburg, MD
That is BS that all the newer trucks have these light guards on them. If that was so most of the trucks that we have would have those light guards on them. That is just not true. Provide proof...
Mine fits that category. I hope to correct that one day.westfolk said:For that matter I have seen trucks that have a flat on one side and a round on the other.
The arch is a stronger structure.Adamlee said:...... the flat guard seems like an OK deal, from an engineering standpoint....
Bjorn, you're right; the arch shape is intrinsically stronger than a flat form with two 90 degree bends. When these guards were manufactured, they required at least one if not more "extra" bends or stamps to create their shape. So from a construction standpoint, the squared-off/"flattop" guards likely cost more in the long run to make; with the extra time to stamp or bend them.cranetruck said:The arch is a stronger structure.Adamlee said:...... the flat guard seems like an OK deal, from an engineering standpoint....
When I replaced my front turn signal/park composits, I had to modify the mounting holes to make them fit the original guards. I can see that they had to redsign it for a better fit, don't know why they made it rectangular (=not as strong), though, styling?
I think it would be more accurate to say SOME not all of the newer trucks....specifically those on contract DAAE-06-68-C-0007.MilitaryRestoration said:Unless someone has put them on themselves, all the newer trucks come with this style of light guard and if it's not a newer truck then it means the truck has visited the rebuild site or has been gone through for a refurbish. just fyi hope that helps out
You've got a good point there - its pretty much midway in the 1949 through 1989 production run.m16ty said:I guess it depends on how you look at it. I wouldn't consider a 1968 contract truck as late. I would consider it early myself.
