Oh no! What have I done? My new M1010
krebsatm02
Bryan, TX
There was! I was tempted to get my friends 32ft gooseneck and load 2 of them up. I'm glad I don't live in Mississippi else I might be divorced!
Anyone know what one of these weighs by any chance?
lavarok
34
Fellsmere, FL
The M1010 weighs in at around 7370lbs. Welcome to the M1010 club. If you need any help once you get her home, let me know. I have spent hours studying the intricacies of the M1010 model CUCV.
krebsatm02
Bryan, TX
Thanks Lavarok. I'll have to see what the fire department has done to it. Obviously it needs a new windshield and god knows what else.
We'll see soon. Obviously I'm excited.
tourdog
madison me
well congrats on the 1010 i also have one here in maine . I did a bad thing though i took the box off to make a flat bad truck . but any way if you need help I have also spent a lot of time with all the in and out of the 1010 . Just beware of the blue box dont let the blue smoke out . If you need i can tell you how to do the easiest 12 volt con. if your blue box is bad. I spent hours trying to find one when i did it was way to much to be worth buying .any way good luck with it
lavarok
34
Fellsmere, FL
What did you do with the rear box? Any salvageable parts inside? I'm interested in you still have it.
tourdog
madison me
i still have the box . i dont know just what is standred to be in it i has the a/c unit was charged all lights heater and gpu in it the to top beds are gone block and tactkle are gone but the out side lope is there . i have slept in it a few times thought were to use as camp were i cant get big camper in .but never know if need some thing pm me we will see if i got it or not .
krebsatm02
Bryan, TX
I'll post some pics later, I've had a rough week. Figured out why all the cab windows are broken... Kids+Rocks.
I can't get fuel to the filter and sub sequentially the injectors. I'll start searching threads.
krebsatm02
Bryan, TX
Got it running. Read a bunch of threads and figured out how to bleed everything.
So I've got some concerns. Someone cludged a 12v alternator on the engine. They dropped the 24v alternator below the 12v.
Why are my images showing up as links and not pictures? I'm using the "
Other pics...
Michael
39
Fulton, MS
Looks like they replaced the top 24v alt with a 12v. That might actually work out better than the stock set up. You will have to let us know and more details on how they did it, if it does work well. Looks like it cleaned up well. How are they running the spot lights, they look like 120 volt?
lavarok
34
Fellsmere, FL
Nice! If you ever want to get rid of the brackets to the front of each bench please let me know. The ones that go from the floor to the ceiling. I see your dome light works as well. I am still troubleshooting mine.
Also, in regards to your charging setup; the stock setup was [2] 24v alts. Sounds like you have [1] 24v and [1] 12v. If so, then the person before you solved the problem with 12v charging by taking out the top 24v unit and replacing it with a 12v. I'd like to see the mounting bracket used. I thought of this prior to installing my battery equalizer.
krebsatm02
Bryan, TX
Anyone know why the pics won't show up?
Interesting about the alternators... I was under the impression there was only 1 24v alternator.
The bracket for the top one was definitely homemade. If kept that setup I'd have to make a new bracket. I work in a machine shop, so I've gotten anal about things.
What I'd really like to do is find a 93/94 6.5 turbo diesel truck with a 4x4 nv4500. Convert to serpentine and use the turbo and manifolds from it.
What in the ambulance runs off 24v? I assume the ac blower motor? Maybe the light? I know about the starter, etc... on a regular m1008.
Also, anyone converted the AC to R134?
Edit: The 24v alternators were 200amps right? Why did they need 400amps???
krebsatm02
Bryan, TX
Also, how much of a demand for parts is there for these things?
I know a guy with a much cleaner one. He told me if I took the drive train out of mine and gave it too him, he'd let me keep the cab/box from mine and give me his complete M1010 for $950.
I'd love to do that, but I can't sink that much money into another one. However, if I could sell some parts, to recoup some of it, I'd be game.
krebsatm02
Bryan, TX
One more post...
My ultimate goal for this is a mile expedition style camper. Hopefully you guys won't shoot me;-)
I have intimate knowledge of this era chevy drivetrain. I went from a stock 88K5 that eventually was on 1 tons, with 38.5 tsl's, crossover steering, etc...
I'd like to put 35's on this. Anyone lifted one of these? Rear shackle flip?
Michael
39
Fulton, MS
I think it was two 100 amp 24v alt for 200amp total @ 24v verses two 100 amp 12v alt for a total of 100 amps of 24v power in the other trucks. The orange wire conversion may cut the total output some also. The extra power was for the NBC filter kit which I have only seen in one truck on GL and the blowers in the AC.
