Oil Cooler Line Leak
96
17
Lees Summit, Missouri
Hello--I have an '86 CUCV Blazer. Today, it developed a small pin-hole leak in one of the oil cooler lines. Of course, the leak proceeded to spray oil all over the engine bay. Does someone have a P/N or source for the line? I might as well replace both of them. The other option would be to take it to a hydralic shop and have the line repaired. Thanks in advance
Tom Lovinggood
MarcusOReallyus
820
Virginia
GM part numbers are in the dash-twenty (TM9-2320-289-20), available here.
Or just buy the part from any online source. It's just an 84 Chevy Blazer with the 6.2 diesel. User cucvrus swears by the Dorman replacements, available just about anywhere online.
No mattress what year your CUCV was actually made, parts are for an 84. The Army wanted standardized parts.
antennaclimber
1,093
State College, PA
I have the local hydraulic shop repair them for me. That way I know the metal lines will fit correctly.
The cost was the same or slightly less than a set of Made in China lines that may or may not fit correctly.
ken
27
Houston Texas
RockAuto.com . I just had one split right by the connector at the block. I took one off of a parts engine I have. But I too will be replacing them both.
DREDnot
617
Phoenix, AZ
I just got a set of dormans finest as recommended by cucvrus.
I got them from summit racing. Part numbers 625-154 @$26.97 and 625-155 @$24.97
I'll see how they fit one of these next few weekends
cucvrus
10,505
Jonestown Pennsylvania
Very easy. Be patient and loosen the 2 M8 nuts on the manifold studs with the bracket if you have alignment trouble. Do NOT force them and only tighten everything once it is all aligned and started properly. Good Luck. Merry Christmas. I have installed 3 sets of the Dorman's in the last 2 months and have 2 more sets for plow trucks to do. Please report back.
cucvrus
10,505
A thin mattress would come in handy for a stubborn set of oil cooler lines. Beats laying on the concrete. Merry Christmas. All in fun.
