oil leak on caterpillar
Coalman
Paxinos Pa
I just noticed ,when I was pulling my tranny on my m35a3, that it has a oil leak on the passenger side somewhere around the turbo. I can't really see where it is coming from or how long it was leaking (i park it on a gravel driveway and never really saw any oil ) When I was working on tranny it is on the cement, and I could see the oil leak. Just wandering where to start looking or if this something common Thanks Kevin
YOUNG GUN
10
Sherwood, Oregon
My A3 has a similar oil leak that I determined is coming from the turbo oil drain tube; it's leaking a tiny bit from where it bolts to the turbo, but mostly where it goes back into the block.
I purchased the seals at the local CAT repair shop which included (2) different o-rings for the bottom, and (1) 2-bolt flange gasket for where it bolts to the turbo. (cost was about $6 delivered)
I'm waiting for my next oil change to replace the seals cause it's nearly impossible to get at with the oil filter on.
Hope this helps
