JasonS
- 199
- 63
- Eastern SD
If you are converting to a better full flow system, why not use one of the combined full flow/ bypass filters?
IMHO, I think it would be pretty safe to run a hose from a banjo bolt straight back, it's fairly high up and on the 5-ton (LDS) engines, the oil pan is installed with the deep part behind the front axle.devilman96 said:Patrick I strongly recommend against installing a oil line at the bottom of your pan, I know a lot of us don't go off roading but most do appreciate the ability in a "need to" situation. Adding a extra 2 inches of length to the drain and a hose to snag is not a good idea... (IMHO of course)..
I think I like a separate small-micron bypass filter better and a separate main filter. Is this a question about the filter having a bypass in it for when it gets clogged up? So I am confused about the question.JasonS said:If you are converting to a better full flow system, why not use one of the combined full flow/ bypass filters?
Is this doable?Ditto... this is why I keep saying spin on bases should be 1.5 inch threads
Yep its very doable... Just has to be made that way. Like I've said... When I can get around to them they will be made like that.Is this doable?
Is anyone planning to offer this?
If you go the remote filter route, you could use the same filter bases that I used. They are 1.5"-12. The Wix 51970XD/51970EX Filters fit. I am using dual 51970XD filters.SasquatchSanta said:D-Man Sez:
