One man landing leg kit
3,150
I kinda don't see the difference between the one in the vid and a well lubed, retractable gear. Now if there were an answer to the non retractable one, they'd be on to something!
ida34
36
Dexter, MI
The part about the M149 was not really correct. I pulled the M149 for my unit and I can tell you that we almost never took the trailer off when it had water in it. If we had to remove it then it did not take 6 people even with it filled. I actually like the older non retractable gear if I have a soldier B. It takes too long to crank it up and down. I would rather just lift it up and down off the pintle. Even when soldier B is not available I can still work it with my Hi Lift jack. You just have to remember to set the brakes before you do it.
nickd
53
Newport, Delaware
I have a newer 105 trailer that has the latest style crank up leg. The handle that changes the position of the landing leg from the stowed(upright position) to the wheel down position has a built in cam that that retracts the 2 pins that lock the leg in either position. This style is much easier to change the position of the landing leg without soldier B.
halftrack
13
New Orleans, LA
Re: RE: One man landing leg kit
I was about to say the samething. Its works very well.
maddawg308
798
Appomattox, VA
RE: Re: RE: One man landing leg kit
Looks very interesting! I like the design, looks a lot easier to operate than the standard locking pin design....
